Power overload cut off
Has liked: 435 times
Been liked: 260 times
Does anyone know if the XT has a safety cut off feature in that if you apply too much power it auto shuts off to protect itself or will it be a case of if you apply too much voltage the XT will be toast?
I don't want to try it for obvious reasons :lol:
Re: Power overload cut off
I don't know, but I suspect not since the manual refers to replacing the in-line fuse - using a new fast blow fuse. If it had in-built circuit protection, I don't think that a fast-blow fuse would be necessary.
iankim
Has liked: 7 times
Post by iankim »
I did read a post (viewtopic.php?p=4755#p4755)
Apparently the user was running the XT via 12v and the only problem was the battery wouldn't charge.
I wouldn't try it just incase.
I have searched high and low and can't find a definitive answer!
I have an adaptor on my R1200rt with a step down transformer and it always worries me that it goes wrong and applies 12v to the XT!
Richard_R
Been liked: 20 times
New Zealand
Post by Richard_R »
The XT works and charges when connected to USB and USB is 5VDC so therefore the XT must require 5VDC. I imagine that there is likely to be a step down transformer (electronic type) within the XT or the XT mount to step the 12VDC from a motorcycle or car to 5VDC for use within the device.
Richard_R wrote: Thu Feb 24, 2022 10:11 am The XT works and charges when connected to USB and USB is 5VDC so therefore the XT must require 5VDC. I imagine that there is likely to be a step down transformer (electronic type) within the XT or the XT mount to step the 12VDC from a motorcycle or car to 5VDC for use within the device.
The step down is a little black box on the wiring but I don't use any of this on my bike
I have this which has its own built in step down viewtopic.php?t=1318
The worry I have is if it goes wrong and applies 12v to xt
Richard_R
New Zealand
Post by Richard_R »
Stu wrote: Thu Feb 24, 2022 10:17 am The worry I have is if it goes wrong and applies 12v to xt
Ultimately it will fry the XT's brain. The only question is how long will it take to do that.
electro_handyman
Been liked: 41 times
Post by electro_handyman »
Stu, I hate to say it, but I doubt that there is any guarantee that Garmin's own power cable with built in 'little black box' couldn't fail and apply 12v to the XT.....
electro_handyman wrote: Mon Feb 28, 2022 11:33 pm
That was my thinking and the reason why I questioned if they had a built in overload protection
It would be interesting to know but I'm not testing it :lol:
electro_handyman
Stu, I here you on that one... I dislike being the guinea pig as well.
Even at work I won't allow system updates to our BAS system until someone else has done them 1st.
