Removing Old Maps From 660
carolinarider09
Has liked: 34 times
Been liked: 40 times
Post by carolinarider09 »
When I updated my maps on my 660 today, I added them to the SD card. There is not much space there and it shows that I still have the 2024.10 maps installed on the card. Is there an easy way to remove them?
If not, one thought would be to just replace the SD card with a new one and then upload the new maps.
Re: Removing Old Maps From 660
Just delete the relevant files
Been liked: 1170 times
This might work - I long since (stupidly) exchanged my 660.
The problem with deleting map files is that you don't know which file name belongs to which map. So this might help you to find out.
Plug in your Zumo and load Basecamp.
Basecamp should show the installed maps in the left hand pane.
Click on the one that you want to get rid of, and it shows some extra details - like this:
The other map (when I click it displays this info
All of the information that you need for the selected map is there. The filename and the location.
Rather than delete the file immediately, I suggest that you rename the file - eg rename d6210270a.img to d6210270a.imgxxx
That way the Zumo will not recognise it as a map, so you can check to see that it has disappeared from the available maps. If so then delete the file.
carolinarider09
Has liked: 34 times
Thanks for the information. I don't use Basecamp but do have it only machine. I will see what I can do. I like renaming the files first. Good point.
carolinarider09 wrote: Sat Nov 11, 2023 3:34 pm Thanks for the information. I don't use Basecamp but do have it only machine. I will see what I can do. I like renaming the files first. Good point.
The dates associated with the map files should let you know which are the latest map files, you can't really go wrong
