How does the Direct activity profile work?
If I were to create a route in Basecamp that had a Direct activity profile, how does the satnav I transfer it to (an XT in my case) know the sequence of waypoints in order to calculate the route as intended?
Re: How does the Direct activity profile work?
Is there a reason why you're using the Direct Activity? That's really aimed at walkers etc.
I suspect if you send a route created using it your Zumo will just recalculate the route using the mapping data it has installed and the various points on your direct route. Bear in mind a Garmin satnav, at least all the recent ones, can only have 30 viapoints in a route.
The numerous discussions in which frustration is expressed due to recalcs by the satnav of routes created in Basecamp or other route creation tools has me wondering what a satnav does with a route from Basecamp created with a Direct Activity profile. I assume it calculates a route but I don't know what goes on behind the scenes for it to know the waypoints sequence to follow.sussamb wrote: Fri Jun 10, 2022 5:50 pm Is there a reason why you're using the Direct Activity? That's really aimed at walkers etc.
There may not be any benefit to having the satnav calculate the route instead of Basecamp but I am curious about what happens.
It sets the Xt to use off-road route preferences. You have to change the route to use faster time / shorter distance / adventurous routing to make the XT calculate the route. It keeps the via / shaping points in the correct sequence.
The light bulb just came on. Got it. Thanks!
