How does the Direct activity profile work?
Has liked: 142 times
Been liked: 448 times
If I were to create a route in Basecamp that had a Direct activity profile, how does the satnav I transfer it to (an XT in my case) know the sequence of waypoints in order to calculate the route as intended?
Has liked: 374 times
Been liked: 383 times
Re: How does the Direct activity profile work?
Is there a reason why you're using the Direct Activity? That's really aimed at walkers etc.
I suspect if you send a route created using it your Zumo will just recalculate the route using the mapping data it has installed and the various points on your direct route. Bear in mind a Garmin satnav, at least all the recent ones, can only have 30 viapoints in a route.
sussamb wrote: Fri Jun 10, 2022 5:50 pm Is there a reason why you're using the Direct Activity? That's really aimed at walkers etc.
The numerous discussions in which frustration is expressed due to recalcs by the satnav of routes created in Basecamp or other route creation tools has me wondering what a satnav does with a route from Basecamp created with a Direct Activity profile. I assume it calculates a route but I don't know what goes on behind the scenes for it to know the waypoints sequence to follow.
There may not be any benefit to having the satnav calculate the route instead of Basecamp but I am curious about what happens.
Been liked: 921 times
It sets the Xt to use off-road route preferences. You have to change the route to use faster time / shorter distance / adventurous routing to make the XT calculate the route. It keeps the via / shaping points in the correct sequence.
The light bulb just came on. Got it. Thanks!
