Speed Camera Warning After Market
JohnnyRidesAlone
- Been liked: 10 times
I can't get on with the Garmin Speed Camera warnings. It is the same sound as the speed change warning.
I use Pocket GPS worlds after market downloads. On the 550/690 and 590 you could set POI in the excel file to ping only once. You changed the @ to a -
But it does not work now. Any pointers or can I get a differnet audio on the Garmin or change the POI files. I have set both to "once" in settings
Re: Speed Camera Warning After Market
I don't know, but can you find the sound file that is being played and change that ?
JohnnyRidesAlone
Thanks Both i shall try both ideas! and report back
- simoncrewe
- Has liked: 47 times
- Been liked: 38 times
I had the PGPSW data base on my 595LM and it worked perfectly including a voice announcing the upcoming camera site. I have now got an XT, running PGPSW as well, but it does not function anywhere near as well, as it did on the 595LM. I get a visual banner at the top of the screen and a 'very' short ping to warn of the camera.JohnnyRidesAlone wrote: Sun May 15, 2022 4:52 pm I can't get on with the Garmin Speed Camera warnings. It is the same sound as the speed change warning.
- Has liked: 183 times
- Been liked: 166 times
I too use the Pocket GPS world safety cameras database and use the female voice with no prefix, Works just like the other Garmin's I've had. It only annunciates once if you're not above the speed limit.
JohnnyRidesAlone
How do you do stay below the limitOop North John wrote: Tue May 17, 2022 7:58 pm It only annunciates once if you're not above the speed limit.
That could be the issue.
With difficulty sometimes when out of townJohnnyRidesAlone wrote: Wed May 18, 2022 8:54 am How do you do stay below the limit![]()
