Speed Camera Warning After Market
JohnnyRidesAlone
Been liked: 10 times
Post by JohnnyRidesAlone »
I can't get on with the Garmin Speed Camera warnings. It is the same sound as the speed change warning.
I use Pocket GPS worlds after market downloads. On the 550/690 and 590 you could set POI in the excel file to ping only once. You changed the @ to a -
But it does not work now. Any pointers or can I get a differnet audio on the Garmin or change the POI files. I have set both to "once" in settings
Been liked: 1170 times
Re: Speed Camera Warning After Market
I don't know, but can you find the sound file that is being played and change that ?
Try posting this question in the PGPSW forum, the experts there will be able to help.
JohnnyRidesAlone
Thanks Both i shall try both ideas! and report back
simoncrewe
Has liked: 47 times
Been liked: 38 times
Post by simoncrewe »
JohnnyRidesAlone wrote: Sun May 15, 2022 4:52 pm I can't get on with the Garmin Speed Camera warnings. It is the same sound as the speed change warning.
I had the PGPSW data base on my 595LM and it worked perfectly including a voice announcing the upcoming camera site. I have now got an XT, running PGPSW as well, but it does not function anywhere near as well, as it did on the 595LM. I get a visual banner at the top of the screen and a 'very' short ping to warn of the camera.
Has liked: 183 times
I too use the Pocket GPS world safety cameras database and use the female voice with no prefix, Works just like the other Garmin's I've had. It only annunciates once if you're not above the speed limit.
JohnnyRidesAlone
Oop North John wrote: Tue May 17, 2022 7:58 pm It only annunciates once if you're not above the speed limit.
How do you do stay below the limit ;)
That could be the issue.
JohnnyRidesAlone wrote: Wed May 18, 2022 8:54 am How do you do stay below the limit ;)
With difficulty sometimes when out of town :lol:
