No Maps on the Basecamp - Urgent help
Raf
Has liked: 16 times
Been liked: 3 times
Italy
Post by Raf »
Hi.
I have a big problem,I am desperate.
On my windows 10 PC I have installed the latest map update,City_Navigator_Europe_NTU_2022_20.gmap. The installation folder is C:\ProgramData\GARMIN\Maps. Until yesterday basecamp has always worked well. I had a problem with garmin express this morning, I had to uninstall it and clean up the windows registry with a software,geek.exe.
After this I opened basecamp and there are only global maps.I uninstalled and reinstalled Basecamp, reinstalled garmin express, did a system restore. None of this worked. I tried to reinstall the maps on my PC using BMW Navigator VI. But at 50% it crashes with red alert. I don't know what I can do.
If I use the maps on my Zumo XT, internal storage, it is very complicated.
The figures explain better.
PC control panel
This is what's on basecamp
PS
There is also no map on MapSource.
Thanks to everyone who will help me
Scarecrow
Been liked: 27 times
Re: No Maps on the Basecamp - Urgent help
Post by Scarecrow »
I had the same problem.
I deleted CN maps from PC then
connected my Zumo and ran Garmin Express then I think its manage Maps/Options/ install on PC
or something similar, restart PC and all was sorted.
Hope this Helps
Raf
Has liked: 16 times
Been liked: 3 times
Italy
Post by Raf »
Thank you very much. I'll try.
Unfortunately, I am unable to reinstall the maps
Raf
Has liked: 16 times
Been liked: 3 times
Italy
Post by Raf »
Now everything is OK. I uninstalled and then reinstalled the maps. Basecamp and Mapsource now works. Thanks again.
Great sigh of relief.
:D :D
Raf
Has liked: 16 times
Been liked: 3 times
Italy
Post by Raf »
OT !!
Do you want to know how badly we are in Italy?
I post the answer of the Italian technical support
" Dear ,
Thank you for contacting Garmin Technical Support.
I confirm that it is not currently possible to install maps on a PC.
In order to view the details of the maps, the navigator must necessarily be connected to the PC via USB cable.
I remain at your disposal and in the meantime I offer you my best regards
Emanuele Vaiana
Product Support
Garmin Italia S.r.l
https://support.garmin.com/it-IT/
:shock: :shock: :shock: :shock:
Raf
Has liked: 16 times
Been liked: 3 times
Italy
Post by Raf »
Unfortunately I have the same problem. I uninstalled old versions of NTU maps using Geek.Damn Geek :oops: . The Windows installer/uninstaller does not allow this. I uninstalled and then installed Garmin Express, Basecamp and the NTU 2025.10 map. Now in Basecamp I have only NTU 2025.10 and global maps. I lost all NT maps for my 660.
In C/ ProgrammData/Garmin/Maps there is a folder called RMU/EU with all the NTU files. Large 4-5 GB. In ProgrammData/Garmin/Maps there are the City_Navigator_Europe_NT_2022_10.gmap files, etc etc of a few MB. How can I get all ,NT and NTU files ,back in basecamp. ?Thanks
Has liked: 378 times
Been liked: 383 times
I always uninstall my old Garmin maps via windows uninstaller so unsure why you cannot, it does though depend on them being installed correctly via Express. Easiest solution for your old NT maps is to copy them to a removable drive, eg a USB stick, and BaseCamp will then read them from there.
Raf
Has liked: 16 times
Been liked: 3 times
Italy
Post by Raf »
sussamb wrote: Tue Apr 23, 2024 7:20 am I always uninstall my old Garmin maps via windows uninstaller so unsure why you cannot,
The uninstallation starts, then there is a warning "user already present" or something like that. But where are the NT versions located? They are present in the Windows uninstaller. But I can't find them in the Maps folder. Yet I haven't touched these. Finally, why doesn't Basecamp see them anymore?
Been liked: 923 times
I would guess that was because you reinstalled Basecamp. That means that you got rid of all of the registry entries which tells Basecamp where to look for the files. Even if the maps are actually on the computer - Your new installation of Basecamp doesn't know where they are.
  • When doing this - always use the default location that Basecamp offers for the maps - don't try to install them anywhere else. That is because Basecamp makes assumptions about the way that Windows locates files in any other location - assumptions which are no longer valid with more recent versions of windows. (I think that it was something to do with the old 'Append' command which allowed a program to search a different folder for files).
Your comment from Tech Support isn't correct. Maybe it has lost something in translation ? Perhaps he saying that it is not possible to install the maps to the computer from those that are on the Zumo. Certainly you can connect the Zumo by USB cable and Basecamp will read the maps from there, but it is very slow. The best solution is to do what you have succeeded in doing, which is to use Express to re-install the maps to Basecamp.
Raf wrote: Tue Apr 23, 2024 8:02 am The uninstallation starts, then there is a warning "user already present" or something like that. But where are the NT versions located? They are present in the Windows uninstaller. But I can't find them in the Maps folder. Yet I haven't touched these. Finally, why doesn't Basecamp see them anymore?
If they are present in the uninstaller you could try uninstalling them and reinstalling them using Express.
