That's not a master reset; that's simply a restart. [emoji38]
Sharing a route via Bluetooth
Re: Sharing a route via Bluetooth
When we receive an update, it says precisely that the XT will (or need) to restart in order for the update to be applied.sussamb wrote:That's not a master reset, but it can help too if all you normally do is put it into sleep mode
But "master reset" and "restart" are 2 completely different things.
Yes agreed, that's why I advised a master reset, it normally clears any strange behaviour after a software update.
- Been liked: 3 times
I stand corrected.XIKO29 wrote: ↑09 Aug 2020 16:25When we receive an update, it says precisely that the XT will (or need) to restart in order for the update to be applied.sussamb wrote:That's not a master reset, but it can help too if all you normally do is put it into sleep mode
However simply switching the units off and then back on, i.e. in and out of standby or sleep mode achieved nothing, it was only when I did the full restart on both units that I was able to carry out the route transfer.
Yep, first try the switch off then on, rather than allowing it to go on standby all the time. That can cure a few issues. Failing that a full master reset.
This is applicable to all Garmin units, not just the XT, although some don't have a standby mode so for those it's simply a master reset.
- Has liked: 94 times
- Been liked: 266 times
I regard a Master Reset to be clearing out all data and returning the unit to its original settings.
This facility is available on Settings->Device->Reset where there are three options. (Clear Travel History, Reset Default Values and Delete Data and Reset Settings).
Turning the unit off completely (Cold Restart) involves holding the power button in for a few seconds and then clickin the red 'Off' button.
There are lots of interesting things available from the hidden system menu.
Main Screen->View Map->Speed button, bottom left->Speedo circle top centre (Press for 10 seconds).
There was once another text based system menu available by holding down the bottom right hand corner after a Cold Restart, and letting go when the copyright screen appears, but it seems to have changed after one of the software updates. I don't know what it is now.
