Sharing a route via Bluetooth
XIKO29
Portugal
Re: Sharing a route via Bluetooth
Post by XIKO29 »
wingrider.steve wrote:
XIKO29 wrote: Sun Aug 09, 2020 11:34 am
sussamb wrote:Worth saying that after a software update a master reset is advisable, and definitely if you're experiencing any issues
How do you do a master reset on the XT?
Press and hold the power switch in until the unit restarts.
That's not a master reset; that's simply a restart. [emoji38]
XIKO29
Portugal
Post by XIKO29 »
sussamb wrote:That's not a master reset, but it can help too if all you normally do is put it into sleep mode
When we receive an update, it says precisely that the XT will (or need) to restart in order for the update to be applied.
But "master reset" and "restart" are 2 completely different things.
Has liked: 380 times
Been liked: 384 times
Yes agreed, that's why I advised a master reset, it normally clears any strange behaviour after a software update.
wingrider.steve
Post by wingrider.steve »
XIKO29 wrote: Sun Aug 09, 2020 4:25 pm
I stand corrected.
However simply switching the units off and then back on, i.e. in and out of standby or sleep mode achieved nothing, it was only when I did the full restart on both units that I was able to carry out the route transfer.
Yep, first try the switch off then on, rather than allowing it to go on standby all the time. That can cure a few issues. Failing that a full master reset.
This is applicable to all Garmin units, not just the XT, although some don't have a standby mode so for those it's simply a master reset.
Has liked: 429 times
Been liked: 938 times
I regard a Master Reset to be clearing out all data and returning the unit to its original settings.
This facility is available on Settings->Device->Reset where there are three options. (Clear Travel History, Reset Default Values and Delete Data and Reset Settings).
Turning the unit off completely (Cold Restart) involves holding the power button in for a few seconds and then clickin the red 'Off' button.
There are lots of interesting things available from the hidden system menu.
Main Screen->View Map->Speed button, bottom left->Speedo circle top centre (Press for 10 seconds).
There was once another text based system menu available by holding down the bottom right hand corner after a Cold Restart, and letting go when the copyright screen appears, but it seems to have changed after one of the software updates. I don't know what it is now.
