Windows 10
patrickg450
Windows 10
Post by patrickg450 »
ok, I need some windows help here. I got a new PC like 4 months ago. I have BC up and running, I want to back up all my tracks and whatnot. I did a search for the folder BC defaults to for saving...........cant seem to find it.
Re: Windows 10
Search for AllData.gdb, that's the BC database folder
Iris
Been liked: 17 times
Re: Windows 10
Post by Iris »
I think you may have to go into the folder view settings and set it so you can see hidden files.
Re: Windows 10
Yes, that's possible, although the default folder should be visible? Anyway if a search doesn't find AllData.gdb then hidden files may indeed be the issue.
Re: Windows 10
Somewhere in the "C" drive on my laptop there's a folder called
"Roaming" in it there's a sub folder,
"Garmin" in it there's a sub folder,
"Basecamp" in it there's a sub folder,
"Database" in it there's a sub folder,
"4.6" which has the data needed to swap from one PC to another, which I used to do when I had a laptop for home use, and one I took away with me.
I strongly suspect that the roaming folder is a hidden one.
khunpaul
Been liked: 5 times
Re: Windows 10
Post by khunpaul »
When I changed pc I did a “backup” on old pc then a restore from that file on new.
The advantage was that all my bought is maps were included in the backup without having to connect a device
patrickg450
Re: Windows 10
OK, I made the change in WINDOWS to see hidden files, yea!!!!!
patrickg450
Re: Windows 10
Did a search for Garmin.........found my old tracks from Mapsource.
FInally found it, GARMIN ---> BC---> Data base---> 4.7--->
there is 2 AllData(s)
.gdb and a gdb.bak
But I cannot navigate to it or see the path to get to the folder
Re: Windows 10
You should be able to go into Edit, Options, General then click on plus under Database options and navigate to it.
Re: Windows 10
Note that you can have as many databases as you want. They all get saved in the same general location. Switch from one to the other from within Basecamp. I put details in the Zumo And Basecamp document I posted a little while back. I'm currently modifying it to include specifics for Zumo 595. When I get to my Pc, I'll post the relevant information here.
Nb I have no problem accessing the database location from within Windows 10. I always have it set to show hidden files though. I didn't think that they were hidden. Most of them are ones that I have created though. I'll check.
