CN EU 2022.20 NTU
Has liked: 311 times
Been liked: 356 times
CN EU 2022.20 NTU
New EU map now available.
axamax
Has liked: 7 times
Been liked: 10 times
Re: CN EU 2022.20 NTU
Post by axamax »
Updated last night but the internet crashed in the middle of download. Now have a blank map, (ie. No roads at all). It will route to a local favourite but not show anything.
In MyMaps I seem to have two copies of CN Europe NTU 2022.20 ALL South (plus CN Europe NTU 2022.20 ALL North)
Location Southern England
Run Express and select the Reinstall map option
axamax
Has liked: 7 times
Post by axamax »
OK thanks. I'll try tonight. I had everything this morning speed limit alerts, cameras, what road I was on, directions etc, but no map
If it's simply not displaying then perhaps uncheck one of the South maps and see if that helps. Also ensure you've done a complete shut down and restart.
axamax
Has liked: 7 times
Post by axamax »
No Luck. Reinstalled map. Tried unchecking the extra south map in MyMaps. Still got the same black display no roads.
Do I need to delete the maps on the Garmin? Or restore to factory settings?
In the .system/Map folder on the XT I have two disc image files that match the ones in basecamp. D6159190A (2.65gb)which also has a matching GMA file and D6210190A(2.57gb) which doesn't have a matching GMA file.
Has liked: 280 times
Been liked: 612 times
Just loaded Express and had a look. it is still reporting 2022.10 for me, which is installed already.
Perhaps other people are having issues and they've removed it again.
I'm in the UK.
axamax
Has liked: 7 times
Post by axamax »
I don't know what to do. Do I delete the maps in the map folder? Factory reset? (The zumo 550 works. Updated immediately afterwards.)
Yes, I'd delete all the map files and run Express again.
axamax
Has liked: 7 times
Post by axamax »
Is that everything in the. System/map folder?
