I do understand that, but I said "problematic", because if I'm somewhere off the route, but between many via points, I don't know which via point I'm closest to. So by selecting randomly from the list, most chances are either go back to vias I've already passed, or to go forward and skip some in the process.jfheath wrote: Mon Oct 18, 2021 3:20 pm
Whicheve Via point you choose from that list (it only lists Via Points) , the Zumo will get you directly to that selected point by plotting its own route. When it arrives it seamlessly tags on the remainder of your planned route and then follows the planned route from that point onwards. For this to work, effectively, you have to have a few Via Points in your route - otherwise you get a choice of the start and the finish. Nothing else (except closest entry point on the XT)
Looking on the via points using the map you don't have a way to know which one is closest to you (at location where you are now) as there is no name or address on or near vias so you could cross-ref with the vias in your list in order to choose it... In this case the "closest entry point" will save the moment and aggravation. However I don't see this on 396.
Hope that I making it clear.
P.S.
I see 2 ways around to sort it out: 1. check the track log and backtrack on it until you find the magenta line and get on it. I'm yet to try it out. 2. Count the number of via points on the map from the start and to where you see "yourself" on the map. Then recount them in the list and go there. Just if too many of them, you can easily loose the count, and do it again... and again.
