Open Street Maps on Zumo XT
seamanstaynes
Has liked: 4 times
Post by seamanstaynes »
Hello
I am looking to upgrade from my Tomtom Rider 410 to a Garmin Zumo XT or a TomTom Rider 550 with world .maps. From what I've read, the Zumo XT is an excellent device but would value feedback from anyone who has done the same. Any regrets from switching systems? Another question is can I use alternative maps such as Open Street Maps on the Zumo. I am looking to travel to Turkey, Iran and the Caucasus in the near future. The ability to do this would be a deciding factor.
Any advice would be gratefully received. Thanks!
Re: Open Street Maps on Zumo XT
No regrets - not now, but I had very mixed feelings when I first bought it.
As always - it is a steep learning curve, but once you get to know its foibles, it does exactly what you want.
OSM maps - Ive installed those, but they do not have any speed limit info, so calculating time of arrival is always very wrong.
But the website for creating OSM maps has been suffering recently. Last time I tried (about a month ago) it reported that it would take over a year to produce the maps that I wanted. Someone may have another site where these can be created.
electro_handyman
Been liked: 41 times
Post by electro_handyman »
I've also used OSM maps on my XT(as an experiment....) and while they can(but not always) be more accurate than the Garmin provided maps when it comes to roads and other geographical details(ie bike trails, attractions, etc...) the OSM still are lacking in other database background info.
Like Jfheath mentioned, the speed limit data isn't there.
The 'search by address' data is mostly non-existent as well so you have to route by stored favorite points or you have to make your route using your destinations LAT/LONG information.
Even despite the drawbacks, I think OSM maps are still a decent viable alternative to purchased maps.
I still use them in my sp2820, and have them for my 550 when Garmin drops the lifetime map updates for it.
seamanstaynes
Has liked: 4 times
Thank you for the great feedback! Currently I use an app called Kurviger Pro to plan my routes on my phone and then upload the gpx file to the GPS unit. As the Kurviger uses OSM and I can easily download all the world maps, I thought integrating the system would make more sense. I wasn't aware of the lack of road speed info as the TomTom had taken care of that!
Should you go down the route of installing an OSM map just be aware that if you have it and the Garmin map selected at the same time you will get very unexpected results, assuming the maps cover the same area, so ensure only one or the other is selected but not both.
HarveyM
Has liked: 10 times
Been liked: 9 times
Post by HarveyM »
You can find a list of websites supplying Garmin compatible Open Street Maps here:
https://wiki.openstreetmap.org/wiki/OSM ... n/Download
some of them ask for money, others not. Plus the tools for creating your own from OSM are available.
seamanstaynes
Has liked: 4 times
Thank you.
Aushiker
Has liked: 14 times
New Zealand
Post by Aushiker »
Bumping an old thread but I have found https://www.openandromaps.org/en/downloads good for map downloads.
Aushiker wrote: Sun Jan 22, 2023 1:35 am Bumping an old thread but I have found https://www.openandromaps.org/en/downloads good for map downloads.
Thank you for the link @Aushiker
Are these maps compatible with Garmin Zumos.
I couldn't find a way to have these installed for BAsecamp or for the Zumo.
Aushiker
Has liked: 14 times
New Zealand
Post by Aushiker »
jfheath wrote: Sun Jan 22, 2023 3:59 pm I couldn't find a way to have these installed for BAsecamp or for the Zumo.
Good point. I haven't received my Zumo yet (thanks Australia Post) so cannot confirm. Having used the site for my Android phones I made the assumption that it would be okay. Sorry about that, I should have double-checked.
I have downloaded the V5 Map and the zip file contains three files. Once my Zumo arrives I will play with the map file and see if it works.
Another option recommended by DCRainmaker and one I have used with my Garmin Edge is https://garmin3.bbbike.org/. Caveat: Still to be tested with the Zumo.
