this is a pic of the files in the .system folder. no sign of a gmapprom.img file.sussamb wrote: Sat May 12, 2018 4:47 pm If Express has replaced the 2013 map with 2018.20 it will be in the .system folder, Map folder is only used for supplementary maps.
Check to see if you have a gmapprom.img file in the .system folder
If not did you allow Express to complete the install and did you do a safe eject from your PC?
Also have you rebooted your Zumo? If so what shows in Settings, Map & Vehicles, myMaps?
(If necessary I will send the map files I've downloaded against that xml file you sent me directly to you to place in the .system folder)
Express did complete the install, but I did not do a safe eject (mea culpa).
have rebooted zumo, and there is absolutely nothing showing in Settings, Map & Vehicles, myMaps? just white screen.
