Customising the warning screen
pcdabbler
Been liked: 5 times
Post by pcdabbler »
Hi guys, new XT owner here. Has anyone tried editing the warning screen on the XT, to include a personal message, is the file structure the same as the 660 ?
Thanks,
Alan.
V-Tom
Has liked: 12 times
Been liked: 15 times
Re: Customising the warning screen
Post by V-Tom »
Don't know but on ADVrider there has been some discussion of changing Line with same way as 590 and I seem to recal a similar discussion when the 590 came out doing the same change as they did on the 660.
..Tom
pcdabbler
Been liked: 5 times
Post by pcdabbler »
Ok, the procedure detailed previously for the 660 and 590 DOES work and the software seems to be in the same format. I've just sucessfully altered the warning screen to include the motorcycle the GPS is usually used on, and a contact phone number if it's found. This procedure has been copied from another site. Obviously use this at your own risk, bear in mind if you screw it up it might make your unit unbootable !
To replace the warning message
1. Connect your Zumo 590/595/660 to your computer
2. Open the folder Text
3. Find, according to your language settings, the correct language file
For UK English, it's en_GB.glx
For Dutch, it's nl_NL.glx
4. Backup the language file, in case something goes wrong
5. Copy the language file to your computer (it's read only when it's on the GPS device)
6. Open and edit the language file in an advanced text editor like Notepad.
7. Find the <entry handle="WARNING_TEXT>" tag
8. Change the text between the next<visual>...</visual> tags into whatever personalized text you prefer, for instance your name, address and phone number (so if found the device can be returned to you)
Do not use any special characters or any HTML tags, it could prevent your GPS device from booting normally!
9. Save the language file
10. Copy the modified language file back to the Text folder on the GPS device, overwriting the previous (original) version
11. Disconnect the GPS device and power it on
Jim1348
Has liked: 26 times
Customising The Warning Screen
Post by Jim1348 »
I was thinking about deleting my screen completely.
It sounds like it has to come up with some message, however.
BrAtKo
Has liked: 17 times
Been liked: 7 times
Slovakia
Post by BrAtKo »
It's nice to have the contact to you there for case of lost or stolen.
Image Honda NC750S DCT fuel consumption (122 000km from 2015y)
Jim1348
Has liked: 26 times
Post by Jim1348 »
That is a great point.
Thank you.
Been liked: 561 times
I haven't been able to figure this out. I can not find a file that starts with "en" (English) that contains the entire text displayed in the warning screen. The file en_GB.gbx contains about half of it but I have not been able to identify the American English file. In en_GB.gbx I couldn't identify where the word "Warning" at the top or the "Agree" button come from. Perhaps they don't appear in the UK version. Regardless, I am curious whether it is just the center text that can be changed.
Has liked: 203 times
Been liked: 286 times
The words 'Do not attempt' can be found in the 'En_GB.glx' file. It looks very much like XML format.
In another forum I have read that the file (possibly) gets overwritten with a firmware update.
<off_topic>Still hoping for a firmware update for RUT! </off_topic>
do not attempt.jpg (147.11 KiB) Viewed 4356 times
Thanks @FrankB . I was searching for the "WARNING_TEXT" tag instead of "WARNING_NOTICE".
It appears that both the American English and British English language options use the en_GB.glx file.
FrankB wrote: Mon Jul 17, 2023 6:13 pm In another forum I have read that the file (possibly) gets overwritten with a firmware update.
I'll bet you are right based on its date/time stamp of 21 Sept, 2022. That is more recent than the purchase date. There are newer .glx files though so it appears that they indeed can be replaced. It is doubtful that a firmware update would replace just the modified ones so, although I like the idea of it displaying contact information, I now wonder if it is worth the effort considering it may change.
@Peobody
You're welcome
Btw: The text appears twice, as you can see in the screenshot.
