Using map themes with BaseCamp
Is this possible. I'd like BaseCamp and my Zumos to use the same colours if possible. I can't find anything in BaseCamp's settings hence the question.
Re: Using map themes with BaseCamp
Individual Route and Track colors can be changed in Basecamp. AFAIK, those are the only colors you can change. I can not find a place where you can change the default color for either one.
- Been liked: 1170 times
What @Peobody said is correct.
You can change things like Rendering Quality, Label quantity, Symbol Size, Track Width, Route Width, Font / Size used on the map and 3D elevation Exaggeration. Most of which are useful. But not that I have found, map colours.
