Ver. 7.16.0
kebo
Slovakia
Ver. 7.16.0
Post by kebo »
New version of Garmin Express available. BUT with the bug (at least for me). During update via Garmin Express, installation failed and I was not able to run Garmin Express anymore. I uninstalled it from PC, downloaded installer from Garmin web:
https://download.garmin.com/omt/express ... xpress.exe and tried install it again.
Now Garmin Express is installed, but I can't add any of my device (NAV V and NAV VI). There is an error message:
GE
GE
Re: Ver. 7.16.0
Express v7.16.0 Release Notes:
  • Fixed an issue with critical software updates not requiring a restart before a map update.
  • Extended timer to prevent failure for installing maps to the computer.
  • Fixed a crash when saving a music folder path manually.
  • Other minor bug fixes and improvements.
Source: https://forums.garmin.com/apps-software ... 0-released
biz
Has liked: 25 times
Been liked: 25 times
Re: Ver. 7.16.0
Post by biz »
When I check for updates (on 7.15.2) it still says I'm up to date. 7.16.0 pulled maybe?
Re: Ver. 7.16.0
v7.16.0 is not offered to me either but it is the version that Garmin is distributing via the Garmin.com site.
Re: Ver. 7.16.0
Peobody wrote: Wed Feb 01, 2023 6:54 pm v7.16.0 is not offered to me either but it is the version that Garmin is distributing via the Garmin.com site.
7.15.2.0 is said to be up to date on my Express.
ZFtracker
Has liked: 22 times
Been liked: 39 times
Re: Ver. 7.16.0
Post by ZFtracker »
I am running GE 7.15.2.0 and it wants to install 7.16.1.0 now, so maybe they found the problem and fixed.
Zumo 590
Montana 610
Drive 60
inReach Mini
Ray N.
Has liked: 12 times
Been liked: 3 times
Re: Ver. 7.16.0
Post by Ray N. »
Ver. 7.16.10 is available this morning.
2021 Goldwing DCT Tour - Zumo XT
biglew55
Has liked: 45 times
Re: Ver. 7.16.0
Post by biglew55 »
Caution!
v 7.16.1.0
loads new maps to unit, but errors on load to PC.
kebo
Slovakia
Re: Ver. 7.16.0
Post by kebo »
I reported my problem to Garmin, still waiting for response. V.7.16.1.0 available for download today, but it did not fix my issue - NAV V nor NAV VI recognized by Garmin Express. Avoid update if you can until they fix all bugs.
Re: Ver. 7.16.0
biglew55 wrote: Thu Feb 02, 2023 2:56 pm Caution!
v 7.16.1.0
I think it's an issue with the new CN NA map. After I had the error, I downgraded to v 7.15 on one computer, did not update from 7.15.2.0 on another. Using an XT and a 590, all combinations gave the same error while trying to install on a PC - "Map changes failed"
EDIT: The failure to update the map on a computer is a map problem, not an Express bug.
Garmin is aware of the issue, see https://forums.garmin.com/apps-software ... 55#1565355. We just have to wait for a fix.
