Ver. 7.16.0
Ver. 7.16.0
New version of Garmin Express available. BUT with the bug (at least for me). During update via Garmin Express, installation failed and I was not able to run Garmin Express anymore. I uninstalled it from PC, downloaded installer from Garmin web:
https://download.garmin.com/omt/express ... xpress.exe and tried install it again.
Now Garmin Express is installed, but I can't add any of my device (NAV V and NAV VI). There is an error message:
- GE
- GExpress.jpg (106.78 KiB) Viewed 11212 times
- Been liked: 561 times
Re: Ver. 7.16.0
Express v7.16.0 Release Notes:
- Fixed an issue with critical software updates not requiring a restart before a map update.
- Extended timer to prevent failure for installing maps to the computer.
- Fixed a crash when saving a music folder path manually.
- Other minor bug fixes and improvements.
Re: Ver. 7.16.0
v7.16.0 is not offered to me either but it is the version that Garmin is distributing via the Garmin.com site.
- Has liked: 183 times
- Been liked: 166 times
Re: Ver. 7.16.0
7.15.2.0 is said to be up to date on my Express.Peobody wrote: Wed Feb 01, 2023 6:54 pm v7.16.0 is not offered to me either but it is the version that Garmin is distributing via the Garmin.com site.
Re: Ver. 7.16.0
I reported my problem to Garmin, still waiting for response. V.7.16.1.0 available for download today, but it did not fix my issue - NAV V nor NAV VI recognized by Garmin Express. Avoid update if you can until they fix all bugs.
- lkraus
- Has liked: 87 times
- Been liked: 248 times
Re: Ver. 7.16.0
I think it's an issue with the new CN NA map. After I had the error, I downgraded to v 7.15 on one computer, did not update from 7.15.2.0 on another. Using an XT and a 590, all combinations gave the same error while trying to install on a PC - "Map changes failed"biglew55 wrote: Thu Feb 02, 2023 2:56 pm Caution!
v 7.16.1.0
loads new maps to unit, but errors on load to PC.
EDIT: The failure to update the map on a computer is a map problem, not an Express bug.
Garmin is aware of the issue, see https://forums.garmin.com/apps-software ... 55#1565355. We just have to wait for a fix.
