I was on a long route (past gas range) and every minute or so I'd get a popup "Distance exceeds gas range, search for gas stops?" I'd click no, and a minute later the same message would appear. After clicking no about 10 times the messages finally stopped appearing.
Is there a way to prevent those warnings from appearing? I've read the manual but didn't see anything promising.
Gas range warning pops up too much
- Site Admin
- Has liked: 424 times
- Been liked: 240 times
Re: Gas range warning pops up too much
I just turned fuel tracking totally off as it was just too annoying I just work on 250 miles and plan for fuel and stopping for the day
- Has liked: 129 times
- Been liked: 101 times
I think its "Apps" - "Fuel Settings" - and then "Unspecify" the distance per tank.
- Has liked: 142 times
- Been liked: 449 times
Me too, although my planning is based on 150 miles.
- Has liked: 421 times
- Been liked: 921 times
I don't use it - I did on the 660 for a while, but it was not very accurate and not as useful as I thought it might be. And having to remember to reset it at each fill up was a pain. Although I think it recognised when you had stopped for fuel. Maybe that is my bad memory, or you had to set it as a destination.
Does the XT recognise when you stop at a petrol station and reset the fuel tank to full ?
It pops up a message "Possible fuel stop detected, reset fuel range?"
