Can I temporarily stop verbal instructions?
Has liked: 436 times
Been liked: 264 times
Re: Can I temporarily stop verbal instructions?
Peobody wrote: Wed Apr 27, 2022 11:17 pm The original hope was to find a way to prevent spoken navigation from interrupting intercom communication. That doesn't appear possible so disabling spoken navigation has been pursued. Intercom communication needs to remain functioning.
Well I'm not sure exactly what you are doing but you must be missing something somewhere as mine works perfectly as does my two mates with the same setup!
Have you made sure intercom has priority on the headset? This can be found in the cardo connect app
Been liked: 560 times
Stu wrote: Thu Apr 28, 2022 7:10 am Have you made sure intercom has priority on the headset? This can be found in the cardo connect app
Yes. I'm leaving shortly on my trip. I'll be back with a report on what I figure out, or don't.
All good today. Spoken navigation was turned off and intercom was never interrupted. I review all settings before departing and everything looked fine so the only difference between it working today and not yesterday was a that the XT was shut down overnight.
Stu, thanks for the guidance!
That is brilliant.
I hope your trip goes well.
I have noted before that sometimes some changes I have made have not worked until after a reboot. I have never tried to find out when a reboot is required.
