I have created a route in Basecamp with around 20 non alerting points which has then been saved as a gpx file.
I have then e-mailed this to a friend who is using an earlier Garmin GPS. He has downloaded it and checked that the route is OK?
My question is that as a gpx file, will the non alerting points have been transferred such that the GPS should/will follow the route as prescribed or can/will it just take any route between the start and destination points that are alerting?
gpx files
Re: gpx files
Well assuming his device can use shaping points it should work as planned. Which device does he have?
Users browsing this forum: CeeBeeA, CommonCrawl [Bot], Google [Bot], mzeist and 1 guest
