gpx files
sprint
gpx files
Post by sprint »
I have created a route in Basecamp with around 20 non alerting points which has then been saved as a gpx file.
I have then e-mailed this to a friend who is using an earlier Garmin GPS. He has downloaded it and checked that the route is OK?
My question is that as a gpx file, will the non alerting points have been transferred such that the GPS should/will follow the route as prescribed or can/will it just take any route between the start and destination points that are alerting?
Has liked: 378 times
Been liked: 383 times
Re: gpx files
Well assuming his device can use shaping points it should work as planned. Which device does he have?
sprint
Re: gpx files
Post by sprint »
sussamb wrote: 25 Aug 2020 13:53 Well assuming his device can use shaping points it should work as planned. Which device does he have?
He has the predecessor to the 396/346 series GPS.
