configurable map boxes
- Has liked: 10 times
- Been liked: 7 times
There are two boxes on the map screen while following a route, one bottom left and one bottom right. The one on the bottom right, when you press on it, can be changed to various things like Distance, Arrive In, Arrival Time. The one on the bottom left shows Speed and can not be changed?? I know how fast I'm going - I have a huge speedo on the bike to do that! If you select the bottom left box it brings up a screen with various things like Distance, Arrive In, Arrival Time - but you can not select any of them? It only ever shows Speed. Is this right?
Re: configurable map boxes
Yes, that's how it works, but you can add 3 additional boxes to right of your screen if you tap the wrench bottom right, then choose Trip data. If you don't see Trip data enable it in Settings, Map & Vehicle, Map tools
Incidentally the speed icon will be way more accurate than your bike speedo
Thanks sussamb thats helpful and answers my question.
Thing is I only use Time to arrive and Distance to arrive. On my 660 I had this on each box left and right. It works great. Adding the 3 extra boxes on the right just covers the map.
As I say, I have a huge speedo on the bike, I don't need an extra one permanently. The fact my bike speedo over reads has probably prevented me from losing my licence!!
