As I said above I dont get that option its not a problemalan sh wrote: ↑30 Apr 2018 08:56But if you follow my instructions, you should be able to plan using the right maps without needing the Zumo to be connected.
Tricky
Re: Tricky
Re: Tricky
If you don't it can only be because you've recently bought the device and it has the latest maps. Once you do your first update after the next map release you will be able to.
- alan sh
- Has liked: 5 times
- Been liked: 22 times
Re: Tricky
My instructions will work even if you have the latest maps
Alan
Alan
Alan
Re: Tricky
Not if you bought a device with up to date maps, Express won't offer a map update or reinstall until a new map is out.
- alan sh
Re: Tricky
Yes it does - for me. Check my document and let me know which bit doesn't work for you
Alan
Alan
Alan
Re: Tricky
I can't as I've updated all my devices. It'll work for you too but it won't if someone buys a new device with maps already up to date. Express won't even show an update until the next map release. At least that's how it used to be and it caused great confusion at times, perhaps Garmin has changed how Express behaves but I've seen no mention of it if they have in any of the changelogs.
- alan sh
Re: Tricky
All my devices are up to date. But I still get the option of saving maps to my PC. My document has screen shots. Are they different for you?
Alan
Alan
Alan
Re: Tricky
Maybe I'm not being clear, I get the same. But for Express to give the option you must have a device that has previously been updated. A new device, with an up to date map, has never had an update. Until it gets the first map update Express won't give the option to reinstall the map or install it to the PC.
Re: Tricky
Have you made sure that the map was loaded into your GPS AND your computer. You have the option of doing one or the other or both. Not much detail in the base map but it's all there if you load it with current maps.
