Tricky
Woody
Has liked: 13 times
Been liked: 3 times
Re: Tricky
Post by Woody »
Thanks everyone. You've given me something to do... :D
Woody
Has liked: 13 times
Been liked: 3 times
Re: Tricky
Post by Woody »
I only see the 595 map when its connected. how do you download to the PC?
Re: Tricky
Run Express and click on the Install options. Select Install to PC only.
alan sh
Has liked: 6 times
Been liked: 26 times
Re: Tricky
Post by alan sh »
Woody wrote: Sun Apr 29, 2018 2:10 pm I only see the 595 map when its connected. how do you download to the PC?
I posted instructions in the Garmin Express pages.
Alan
Alan
Woody
Has liked: 13 times
Been liked: 3 times
Re: Tricky
Post by Woody »
sussamb wrote: Sun Apr 29, 2018 4:27 pm Run Express and click on the Install options. Select Install to PC only.
Thanks however I dont get that option
Re: Tricky
Have you been able to update the maps on your device? If so you should have the Install options when you select the map in Express. See also the instructions alan sh mentioned.
Has liked: 435 times
Been liked: 260 times
Re: Tricky
Woody
Has liked: 13 times
Been liked: 3 times
Re: Tricky
Post by Woody »
sussamb wrote: Sun Apr 29, 2018 7:40 pm Have you been able to update the maps on your device? If so you should have the Install options when you select the map in Express. See also the instructions alan sh mentioned.
Morning. I have updated everything I'm on v6.4 (when checked via Properties) express, I dont get the option to PC only. also the latest map for my 595LMTE its not a problem I can get the latest maps when the Zumo is connected.
Woody
Has liked: 13 times
Been liked: 3 times
Re: Tricky
Post by Woody »
Stu wrote: Sun Apr 29, 2018 7:50 pm instructions here if it helps
http://www.zumouserforums.co.uk/viewtopic.php?f=26&t=38
Thanks Stu, I found that in Map updates.
alan sh
Has liked: 6 times
Re: Tricky
Post by alan sh »
Woody wrote: Mon Apr 30, 2018 7:25 am
But if you follow my instructions, you should be able to plan using the right maps without needing the Zumo to be connected.
Alan
