Routes Present Even After Power Cycle
Jim1348
Has liked: 26 times
Post by Jim1348 »
I have several blue lines present on my Garmin Zumo XT every time I turn it on. It looks like a straight line route that just won't clear. Do I need to do a master reset to get those to clear out?
Re: Routes Present Even After Power Cycle
Could they be tracks showing on the map?
Jim1348
Has liked: 26 times
Post by Jim1348 »
Maybe. How do I tell?
How do I get rid of them?
Go to Apps > Tracks. Select each saved track in turn. When each is selected, the screen will change to show it on a map. Tap the spanner (top left) then scroll down the "Edit Saved Tracks" options list until you see the "Show on Map" option. Make sure that is unticked for each one.
Jim1348
Has liked: 26 times
Post by Jim1348 »
Thank you. That did the trick and they are gone now!
