Routes Present Even After Power Cycle
I have several blue lines present on my Garmin Zumo XT every time I turn it on. It looks like a straight line route that just won't clear. Do I need to do a master reset to get those to clear out?
Re: Routes Present Even After Power Cycle
Could they be tracks showing on the map?
Go to Apps > Tracks. Select each saved track in turn. When each is selected, the screen will change to show it on a map. Tap the spanner (top left) then scroll down the "Edit Saved Tracks" options list until you see the "Show on Map" option. Make sure that is unticked for each one.
