Hi all,
I have used basecamp for a while on old 390Zumo and BMW Navigator VI (Garmin 660) and thought I could work my way around ok having done lots of routes etc.
However, changing to the XT has got me really wound up.
First of all I am not seeing all the map detail, yes I am not using the basic map display and I am using the maps in the XT. Howver I realised that the EU countries other than France do have the data but not France or Germany, Belgium / Netherlands is all ok
I have added all the maps and have two for Europe which split the detail level and two that are Topo maps
So if I want to travel from France through to germany I need to create different routes for each map.
Is there any way to combine these so I get the detail for all of Western Europe?
Many thanks
Phil
Map issue with XT
- Has liked: 1 time
Re: Map issue with XT
Are you viewing your XT maps in BaseCamp and only seeing the one there? This is because BaseCamp can only view one map at a time.
The solution is to install the Western Europe map to your computer for BaseCamp to use. Unlike on your XT it is only one map so you will be able to use the whole map.
- Has liked: 1 time
Thank you, I thought I had installed both on the computer but will give that a try
Note 'both' aren't installed on your computer. Only one is and it's the full combined map.
