New software available. Anyone know anything about it?
This morning my XT is showing a software update available (I currently have 6.50). No joy with finding anything about it via an internet search nor did a find any kind of Garmin firmware release notes log. Does anyone know anything about it or how to find out about it?
Edit: I have edited the subject of this post replacing the word "firmware" with "software".
Has liked: 435 times
Been liked: 260 times
Re: New firmware available. Anyone know anything about it?
Its just a time zone map and just says emergency update
Its not a software/firmware update as such in that it would help with bugs etc
Thanks Stu. I was unsure whether hitting the "Software" button would display details or directly initiate the update.
Peobody wrote: Thu Jul 21, 2022 3:21 pm Thanks Stu. I was unsure whether hitting the "Software" button would display details or directly initiate the update.
I did it through garmin express and so far no one has died :lol:
Stu wrote: Thu Jul 21, 2022 3:21 pm I did it through garmin express and so far no one has died :lol:
Using GE...Living on the edge!
I didn't know a software update could be done with GE. I thought it only updated maps.
I love this forum. I learn something with almost every visit.
Peobody wrote: Thu Jul 21, 2022 7:07 pm
I prefer a cable connection and besides doesn't the Zumo require it to be plugged in to a charger before it will update too? so its far easier for me to just plug it in to my computer and update via GE
Re: New software available. Anyone know anything about it?
I don't allow the XT to connect and update through a wifi connection, and always use Express.
When using Express, BEFORE you select the option to update, you can display a screen of information showing a few additional details. I have been maintaining a thread of those screens - the ones that I remembered to capture - here :
viewtopic.php?p=7892#p7892
The terms firmware and software seem to have become confused in recent years from their original definitions - probably partly as a result of the availability of random access memory that retains its contents even when power is lost.
My understanding was that firmware was the stuff that is built into the hardware of the device, and which is not normally alterable simply by loading in a new version. Changes would normally require 'flashing' the relevant special read only memory (Eprom, Earom or whatever else they have developed since I lost touch with this stuff). The sort of thing that you might do to the BIOS of your computer, or your network router just once in a blue moon. It is always available and doesn't need to be loaded into active memory each time the device is turned on.
Software was the stuff that needs to be loaded into the device's memory before the system can work - like a computer's operating system - Windows or iOS or Android.
But things change and I am no longer up to date with this stuff.
Garmin always refer to their updates (currently 6.50) as software - but you have to search for both 'firmware' or 'software' if you want to find answers to questions on forums, as most people would not know the distinction
Stu wrote: Thu Jul 21, 2022 8:28 pm I prefer a cable connection and besides doesn't the Zumo require it to be plugged in to a charger before it will update too? so its far easier for me to just plug it in to my computer and update via GE
AFAIK all Garmin devices that update over Wifi have to be plugged into power to update. Reason for that is that if the battery goes flat part way through an update the unit will be toast.
