Checking for update
Checking for update
How do you stop the XT from checking for an update every time it turns itself off?
Re: Checking for update
Nope that didn't work. The WIFI is switched off and it still checks for updates before shutting down
- Site Admin
- Has liked: 321 times
- Been liked: 158 times
I have just checked mine and can't see any settings relating to updating when turning off
Mine also doesn't check for updates! it just turns off
- Has liked: 1 time
- Been liked: 18 times
Whenever I have the XT connected to an external power source, and that power source is lost before I push the power button, the XT always checks for updates and then turns off. However, it you push the power button while under battery or external power, it will just go into sleep mode. If you push and hold the power button, it will being up a dialog asking if you want to shut it off (not sleep mode - OFF).
Users browsing this forum: CommonCrawl [Bot], Semrush [Bot] and 0 guests
