New guy from Northern California
Hi, I just found this forum and think it's great to have a dedicated Zumo forum. I have been using a Zumo 660 for a long time now and just ordered a new Zumo 595. I hope to get a lot of good information about it here.
Jim Diebolt
Zumo XT
2015 Kawasaki 1700 Voyager
Northern California, USA
Zumo XT
- Site Admin
- Has liked: 437 times
- Been liked: 264 times
Re: New guy from Northern California
Hi and welcome to the forum
It may seem a bit bare at the moment as we haven't been up and running that long but we have a wealth of knowledge in the members
- kernowing
- Has liked: 135 times
- Been liked: 61 times
Welcome to Zumo User Forums JD.
Did the 660 give up or did you just fancy an upgrade?
2007 GL1800 Goldwing
Zumo 660LM
Zumo 660LM
Thanks!kernowing wrote: Sun Jul 15, 2018 7:18 pm Welcome to Zumo User Forums JD.![]()
The 660 is still going but it takes 2.75 minutes to boot up the map now. Seems to be slower than when it was new. I will most likely sell it if I can.
I have always wanted the top of the line for the Garmin Zumo and this one was a good deal at under 760.00 with two tire pressure monitors included and no sales tax.
Jim Diebolt
Zumo XT
Zumo XT
- Wingstyle
- Has liked: 1 time
- Been liked: 11 times
Welcome JD.
I have a 660 and it took a long time to boot with lots of mp3 files on the microSD. If I removed the card it booted fast. I can't remove the card now since the maps are now on it. But I'm sure the boot would be faster if I deleted my music.
That is a good deal on your upgrade. I'm sure others on this forum will be helpful if you have questions with your new 595.
- dave726
- Has liked: 5 times
- Been liked: 8 times
No more than 20 mp3 files in one folder will significantly speed up booting.
My suggestion:
SD:mp3\00\[20 mp3 files]
SD:mp3\01\[20 mp3 files]
SD:mp3\99\[20 mp3 files]
My suggestion:
- Wingstyle
- Has liked: 1 time
Thanks Dave726, you are absolutely correct and your knowledge will no doubt help others. However, I have mine with less than 20 per folder but it still takes time. I think it is because I have some album art messed up and may also have a corrupt mp3 or two. These files/folders have been moved, modified, copied, etc over the years and I am just too lazy to try and find the issue. The good thing is mine don't take 2 to 3 minutes. It is more like 45 sec to a minute, so not worth the effort to me. I just turn on my unit and then get ready to ride (gloves and Helmet) and when I pull out the unit is typically ready.
