XT_Alerts on Map
XT_Alerts on Map
When driving I get Icons on the map, showing nearby restaurants and banks,
but seldom (if ever) see gas stations - even I'm when driving right by them.
How or where do we set what "Icons" for these appear on the map ?
I really don't care about banks, I'd mostly just like to see restaurants and gas stations.
Where can I select which alerts display on the map ?
Thank you....
Thank you....
Re: XT_Alerts on Map
I will try that, next time I ride, apparently the icons don't display off the bike.sussamb wrote: Thu Aug 13, 2020 9:51 pm Tap the icon, then when you have the list up tap the spanner icon and you can then customize the list
Will tapping the icon bring up the "Up Ahead" settings? I ask because trying that (parked) I can't get anything to change.
Thanks...
Vespamarc
- Has liked: 1 time
- Been liked: 14 times
Customizing the Map Layers
You can customize which data appear on the map, such as icons for points of interest and road conditions.
Select Settings > Map & Vehicle > Map Layers.
Select the layers to include on the map, and select Save.
- simoncrewe
- Has liked: 47 times
- Been liked: 38 times
Page 12 of the owners manual.larryg wrote: Thu Aug 13, 2020 10:20 pmI will try that, next time I ride, apparently the icons don't display off the bike.sussamb wrote: Thu Aug 13, 2020 9:51 pm Tap the icon, then when you have the list up tap the spanner icon and you can then customize the list
Thanks...
Yes, I am selecting Up Ahead.sussamb wrote: Fri Aug 14, 2020 5:59 am They should show off the bike, are you selecting Up ahead from the menu?
Off the bike, I see no icons on the map - even though displaying an area nearby with multiple restaurants.
Again, I saw tons of icons while riding recently (but no gas stations).
When I do this, it brings up the same three things I see when clicking on the map (3 dots),Vespamarc wrote: Fri Aug 14, 2020 7:03 am Customizing the Map Layers
Motorcycle Locations
Banks & ATMs
Restaurants
In neither location do I see how to add or delete items that will display, only arrows to move them up or down on the list.
This shouldn't be so convoluted, but:
Thanks for all the help !
OK, I think I've figured it out.sussamb wrote: Fri Aug 14, 2020 7:02 pm Just tap the one you want to change, so the screen where you see the up/down arrows just tap the text ...
Apparently you can only select three things, so to delete one you have to do a Custom Search on that item to replace it.
So, all good here now, thanks for all the help !
