Bummed to see that others have waited months. I have a long trip planned and really want the GPS to be secured.
I'll quit whining now and suck it up!
All the RAM mounts I've ever had had a handle to undo the extension clamp, I use something like this https://www.ebay.co.uk/itm/A2-STAINLESS ... SwZ2pcbGPP to replace the handle so it's harder for a nasty person to take away the clamp / GPS mount. Quite a bit cheaper than this from RAM https://www.ram-mount.co.uk/7-pinlock%C ... 55aoip04d4Skipper wrote: Mon Jul 06, 2020 5:05 pm What I ask myself is if there also is provisions to protect the RAM mount from being unscrewed
which is quite easy otherwise. Can't really find out from the description provided.
Most people normally mount the TT mounts onto a 'bar' 12mm or flat on a dash / nav tower. They are supplied with 12mm clamps to suit a bar type application. I don't think I have seen one used in connection with a ram mount.Skipper wrote: Mon Jul 06, 2020 5:05 pm I am sure Touratech has is a good lock for the unit, although a bit complicated in its construction
as was the previos one in my opinion.
