Basecamp Update
Has liked: 311 times
Been liked: 356 times
Re: Basecamp Update
Yes, seems Google have now fixed the issue but as mine is working I'm not going to update yet. Would be good to know it does actually resolve the link with BC issue :)
Sleuth
Has liked: 14 times
Been liked: 16 times
Belgium
Re: Basecamp Update
Post by Sleuth »
Thanks for the update, I had despaired of ever getting the link to work.
It works like a charm!
The only sad thing - I had to reinstall GPSBabel on the C Drive, it was located on the D drive, still that is a minor thing.
Best regards
Sleuth
Maps: Europe NTU 2024.10
Re: Basecamp Update
Just a note of caution. On the Garmin forums there is still an issue with the link on 4.7 so stick with 4.6 if you want the link to GE.
alan sh
Has liked: 5 times
Been liked: 26 times
Re: Basecamp Update
Post by alan sh »
I can confirm the fix works with mapsource as well.
Alan
Alan
kernowing
Has liked: 128 times
Been liked: 55 times
Re: Basecamp Update
Post by kernowing »
sussamb wrote: Fri Jun 22, 2018 7:19 am Just a note of caution. On the Garmin forums there is still an issue with the link on 4.7 so stick with 4.6 if you want the link to GE.
So, having installed version 4.7 (and cannot link to GE) how do I revert back to 4.6 (if possible)?
As Alan sh notes, GE 32 bit works fine on Mapsource.
2007 GL1800 Goldwing
Zumo 660LM
Re: Basecamp Update
You can download the 4.6.2 exe file from the Perry site, although it's in the MapSource folder.
http://gawisp.com/perry/mapsource/
joebedford
Re: Basecamp Update
Post by joebedford »
sussamb wrote: Fri May 25, 2018 2:36 pm You can get it here http://gawisp.com/perry/mapsource/
I did - install failed and it clobbered my version 4.7
EDIT: I reinstalled 4.7 then explicitly deleted it using Windows 10 programs app. Then I installed 4.6.2 as an administrator. All is working fine now including GE link.
Has liked: 77 times
Been liked: 44 times
Re: Basecamp Update
Back to 4.6.2 as well now. Just needed to import the two "Alldata" and two "Allfolder" files from 4.7 into 4.6 so that the routes etc made in 4.7 now show in 4.6.2.
advnzer
New Zealand
Re: Basecamp Update...dont do it!!!!!
Post by advnzer »
Do not update to basecamp 4.7 if you are a open maps uder!.You will find that mapinstall will not update the new image completely!
Go HERE for the remedies and work arounds!!!
