Introducing TripManager
Raf
Has liked: 16 times
Been liked: 5 times
Italy
Re: Introducing TripManager
Post by Raf »
Hi! I downloaded the latest version of Trip Manager, 1.3.0.147. TripManager-main.zip. I can't find the setup exe. I can't install. Can you help me? Where is the .exe file? In the "Setup" folder there is only the setup.iss file.
Windows 10.
The .zip file is the source code. The program installer is the setup_TripManager.exe file. Download and run that. It will install TripManager on your PC.
Raf
Has liked: 16 times
Been liked: 5 times
Italy
Post by Raf »
I downloaded the file TripManager-main.zip. It's the only one I found. I can't find the file setup_TripManager.exe. Maybe I need to download another file? Can you send me a link?
It's here: https://github.com/FrankBijnen/TripManager/releases
Edit: At the end of each version section is "Assets" which is where you'll find the files available for download.
Do not download a zip file.
Go here: https://github.com/FrankBijnen/TripManager/releases
Scroll down and click on setup_TripManager.exe :
Raf
Has liked: 16 times
Been liked: 5 times
Italy
Post by Raf »
Found it!
Thanks @Peobody ,@ lkraus
JS_racer
Has liked: 11 times
Post by JS_racer »
installed the latest version, had the version before installed...
the latest version 1.3.0 displays tiny, like super small text, the box is tiny.. not sure what changed... the 1.2.0.125 didn't have that problem, it worked perfect in that regard..
not sure what i can do to change it, but its unusable for me..
shame, i was working with my xt and xt2 this morning, and updated the trip manager since I saw it was better with the xt2..
**had to go into high dpi settings, and change override to system... that seems to have gotten me back to seeing it**
JS_racer
Has liked: 11 times
Post by JS_racer »
trying to rename xt trips, some worked...
lots giving errors..
copy failed and other errors...
also under poi, gpi format not supported error??
(not sure if normal, or rolling back would help, or just manually copy trips from the xt to xt2... )
JS_racer wrote: Fri Apr 18, 2025 11:47 am **had to go into high dpi settings, and change override to system... that seems to have gotten me back to seeing it**
Version 1.3 has HIGH-DPI support. It should look at a lot sharper when the Display scaling is set to a higher value than 100 %
The high dpi settings are the way to go, if you want the old behaviour
JS_racer wrote: Fri Apr 18, 2025 12:18 pm trying to rename xt trips, some worked...
Please provide more details, screenshot, a short description what you were doing, etc. if you want me to have a look.
JS_racer wrote: Fri Apr 18, 2025 12:18 pm or just manually copy trips from the xt to xt2... )
That will definitely not work. The format of the XT and XT2 is not compatible
