Guess I go through the process - again.
"Files Too Large" for update
Re: "Files Too Large" for update
Wow!, that's crazy. My original 550 is only using a 4 GB card.
'95 Kaw Concours (207K), '02 Kaw KLR (60K), '67 Honda CL77 305 Scrambler (15K), '22 900 Ace Ryker Sport (5K and counting)
That's it. I'm done fooling with this thing for a while. I've tried a number of SD cards from 8 gigs up to 32 gigs and get the same error: unable to complete route - out of memory. Gotta be something else going on.
MSTOCK27370
- Has liked: 22 times
- Been liked: 44 times
When you connect the Zumo 550 to your computer are you able to use File Explorer to look at the SD card as well as the GPS internal drive?gbyoung2 wrote: Fri Mar 21, 2025 9:00 pm When calculating a route, if it has to go any distance, it goes to a certain %, usually just above 25, then hangs up. a note eventually pops up say that there's not enough memory to complete the route.
The SD card I'm using is an 8 GB, but this sounds more like an internal memory problem. Or is it?
How much free memory do you have on the Zumo internal drive?
Michael S.
Trinity, North Carolina
Yes it is, nothing you can do about it except split routes that won't calculate into 2 separate routes.gbyoung2 wrote: Fri Mar 21, 2025 9:00 pm The SD card I'm using is an 8 GB, but this sounds more like an internal memory problem. Or is it?
- twowheelstom
- Has liked: 146 times
- Been liked: 54 times
another option instead of a long route is to make waypoints then on the 550 just select that waypoint as a destination and allow the 550 to calculate the route, doing it that way will allow you to change your route and the 550 will automatically recalculate, just having waypoints might not take up much of the 550 internal memory space
Zumo 396
1994 Yamaha 250
1994 Yamaha 250
The below is what I’m seeing and is what I think you’re asking:MSTOCK27370 wrote: Sat Mar 22, 2025 1:36 amWhen you connect the Zumo 550 to your computer are you able to use File Explorer to look at the SD card as well as the GPS internal drive?gbyoung2 wrote: Fri Mar 21, 2025 9:00 pm When calculating a route, if it has to go any distance, it goes to a certain %, usually just above 25, then hangs up. a note eventually pops up say that there's not enough memory to complete the route.
Without the SD card installed, when I connect the 550 to my computer, it shows up as drive D:
If I install the SD card, it shows up as drive F:; The D: drive is showing.
If I look at the properties of drive D:, it says used space is 1.01 GB, with a free space of 119 MB.
If I look at the properties of F: drive, it says used space as 3.68 GB, with a free space of 26 GB.
FWIW – if I run a previous route with the SD card removed, it’ll go to about the same % place as before when it craps out for lack of memory.
I have screen shots of drive D: and drive F: contents if you need to see those.
- twowheelstom
the zumo might be using Internal Memory to do route calculations, maybe connect 550 computer and go thru Internal Memory and copy unused files to a new folder on computer, (just to be safe), files like foreign language files and vehicles you don't use, copy those to your computer then delete them on the 550 to make more room for Internal Memory route calculation space, deleting files from zumo Internal Memory can be risky, just be sure its files the 550 doesn't need for functioning operations.gbyoung2 wrote: Sun Mar 23, 2025 4:04 pm
Zumo 396
1994 Yamaha 250
1994 Yamaha 250
