Garmin Express 7.24.0 has been released
Garmin Express 7.24.0 has been released.
Release notes:
  • Removed toast notifications indicating an update is available for legacy PND devices.
  • Fixed an issue with users getting a server error when attempting to register TruSwing devices.
  • Fixed an issue with not offering an install or reinstall option for TOPO Active maps.
  • Fixed an issue with displaying incorrect mapping when a user is wanting to remove a map.
  • Fixed an issue when a user attempts to install a map but would get taken back to the device dashboard.
  • Fixed an issue with the Removable Storage option not appearing on the Manage Maps screen.
  • Other minor bug fixes and improvements.
Re: Garmin Express 7.24.0 has been released
I have installed and done an initial test of GE 7.24.0. This is what I check during my initial test:
- Does it recognize my XT? Yes
- Did the launch at startup option get enabled? No
- Did the keep running in background option get enabled? No
- Does the option to install maps to computer exist? Yes
Just a 'heads up' to let you know that when I started my XT following the GE check and disconnection from the PC, it did the 'do you want to import' prompt even though I had not transferred any new routes. I answered in the affirmative out of curiosity. It was the route in temp.gpx. That route had been imported, ridden, and deleted many weeks ago. The mechanism that keeps track of routes already imported from temp.gpx must have failed. I was not able to duplicate it so this is just an FYI.
turbo19
Has liked: 193 times
Been liked: 47 times
Andorra
Post by turbo19 »
Peobody wrote: Sat Nov 09, 2024 7:45 pm I have installed and done an initial test of GE 7.24.0. This is what I check during my initial test:
In my case, with a XT2...
- Does the option to install maps to computer exist? NO
I don´t know why, but I can only reinstall the maps in the XT2, but not in the PC :(
twowheelstom
Has liked: 146 times
Been liked: 54 times
Post by twowheelstom »
turbo19 wrote: Thu Nov 14, 2024 4:03 pm
to check what my XT does in Garmin Express, I noticed that under Map Updates Available, when I click on Map Details, the map details screen shows Options, when I click on Options, that's where I see Install Map to Computer. 8-)
Zumo 396
1994 Yamaha 250
turbo19
Andorra
Post by turbo19 »
twowheelstom wrote: Fri Nov 15, 2024 7:22 pm
Normally the option is there, but in the case of the XT2 and the Express version 7.24.0.0 that option does not appear to install on the computer.
Thanks ;) ,
twowheelstom
I remember Express showing 3 options on installing new maps, 1. to computer only, 2. to device only, 3. to both computer and device.
are these options still available on the current version of Express 7.24.0 ?
Zumo 396
1994 Yamaha 250
turbo19
Andorra
Post by turbo19 »
With this new version I can only reinstall the maps in the XT2. There are no the other options :(
Installation to Zumo XT and installation to PC are separate steps in Express 7.24.0.
Map Details -> CNNA Options :
pdrt
Post by pdrt »
turbo19 wrote: Thu Nov 21, 2024 8:09 am With this new version I can only reinstall the maps in the XT2. There are no the other options :(
I have the same problem: Map Details, Options only shows "Reinstall Map".
Garmin Zumo XT2, Software Version 4.80, Map Europa 2025.20
Garmin Express Version 4.24.0.0
Windows 10 Pro
