I have just purchased the XT and have not even switched it on yet, dont want the same thing to happen via a map update.skellum wrote: Mon Jan 09, 2023 11:33 am I also had the same problem when updating a 390LM - It also initially said it couldn't unlock maps - I used the Garmin support chat line and their answer was that I needed to upgrade to a new unit!
So the unit is left with just Southern Europe Maps installed and Garmin Express has no option to change maps - only to re-install the current map. Looking at a number of forums it would seem a lot of other owners are having the same issue so hopefully Garmin will come up with a 'fix' soon!
PS. I had no such problem when I updated my XT.
Another thing that has happened is tjhat when I have updated to PC via Express, Europe 2023.2 is not showing any data Express says that it uploaded successfully but there is no zoomable info, just a base map.
Is my ability to update maps to PC linked to the Zumo 390LM?....this is the only device at present on Garmin Express.
Chris...
