question after upgrading map on computer
I just got my Garmin XT earlier this year, first Garmin GPS. I learned how to use basecamp and I really like it. When I hooked up the device for the first time it installed city map 2022 into basecamp. I just upgraded to city map 2023 in basecamp. How will this affect the routes I have all ready made? 2022 is still installed so I am guessing that nothing will change but going further it will make my new routes using 2023. Is this correct or will my old routes be upgraded using the new maps? I hope this makes sense cause it does in my head
Re: question after upgrading map on computer
Connecting your device doesn't install the map to your PC, you need to select the relevant option in Express to do that. What you may have this confused with is BaseCamp, the first time you connect your device, indexing the map so you can use it but it requires your device to be connected to view the map.
As for routes, when maps update some routes may be fine, others will require a recalculation either in BaseCamp or on the device. You'll spot those as they'll consist of a series of straight lines.
I did load the new map, 2023, through express. On the pull down menu on the top left that shows the maps I have both 2022 and 2023. My question is this, will my old routes be upgraded to the new map or should I just recalc all the routes for the change
