BC wants a detour when its not necessary!
Fourbears
Been liked: 6 times
Post by Fourbears »
Does anyone know why BC is taking the detour in the image below instead of the route in MRA, also below? I have put a via point in on BC but it still wants to take a detour!
BC 1.JPG (84.32 KiB) Viewed 2009 times
MRA 1.JPG (82.58 KiB) Viewed 2009 times
Re: BC wants a detour when its not necessary!
Looks like a map error. I'll check it out and get back to you.
Edit: doesn't do it if driving, walking, RV etc activity selected but does if motorcycling or cycling is selected. I need to look at the HERE map as they provide the map data to Garmin
groundhog719
Has liked: 12 times
Been liked: 5 times
Post by groundhog719 »
I've had BC do that quite a few times. If I zoom in and start dropping via points I can find a place where it will not allow the route to continue. Usually, I can then zoom in all of the way and place a new via point right next to the last point BC will plot (in the proper direction) and force it to jump the invisible "gap" in the road.
I've now had a good look at the HERE map. Everything is configured correctly but BaseCamp won't, using any of the cycling profiles, route around the roundabout on the A414. Worth reporting it as a map error to Garmin.
