103 XT Routing Issues
See Pic 4. In Basecamp, I had named all of the points (except the Start) with a leading 3 digit number to represent mileage. The XT has changed 2 of these - The Green Welly Stop and Hunters Quay.
Unaltered names usually show the lat/long coordinates. Altered ones often have a road, county or other address info,
- Select the routes you want to transfer in BC.
- Set the map in BC to an earlier version. Recalculate the route(s).
- Set the map in BC to the current version. Recalculate the route(s).
- Transfer the routes to your XT.
A foolproof way is to retain your route point names is to ensure that the named location appears in Favourites (Saved - USA).
To do this, make sure that they are created in Basecamp with the 'Waypoint' or 'Flag' tool.
Some routing software does not make use of Garmin's waypoints, so no ordinary routepoints are transferred to Favourites. (eg MRA). On the other hand, Kurviger creates every route point as a Garmin Waypoint, so all of them are listed in the XT Favourites / Saved.
