Welcome to the forums !
Glad you managed to find the maps. You need to make sure that your Zumo and Basecamp are both using the same version of the map. I notice that you still have two other versions on the computer - check that Basecamp is showing the correct map on the menu bar drop down selection box.
Also - if you load routes that have been created using the older maps, make sure to recalculates them for the newer map if you wish to transfer to the Zumo again.
Garmin Express no Longer Allows Map Downloads To Computer
- Has liked: 87 times
- Been liked: 256 times
Re: Garmin Express no Longer Allows Map Downloads To Computer
Just an update, I got so fed up with Basecamp that I've now converted to My Route App, what a revelation! So much easier to use and the option to overlay Michelin or Google maps is a joy.
