Test road book with many many point
communicator
Been liked: 6 times
France
Post by communicator »
Testing with "non-alert" crossing points:
1) Test with 66 (1 departure + 064 + 1 arrival) points and no route splitting
2) Test with 107 (1 start + 105 + 1 finish) points and no route split
3) Test with 156 (1 start + 154 + 1 finish) points and no route split
4) Test with 618 (1 start + 616 + 1 finish) points and no route split
5) Test with 991 (1 start + 989 + 1 finish) points and no route splitting
The same route with 991 points in "Alerted" mode, so...CQFD (in French : Ce Qu'il Faut Démontrer...What needs to be demonstrated):
On s'en fout de connaitre la vérité, l'essentiel c'est d'avoir raison (Me Eric Dupond-Moretti)
It doesn't matter what the truth is, the important thing is to be right (French Lawyer Eric Dupond-Moretti
Fun is not a straight line !!!!
JohnnyRidesAlone
Been liked: 9 times
Re: Test road book with many many point
Post by JohnnyRidesAlone »
I found that if you save your Basecamp files as a .gdm file instead of a .gpx the file goes over to the XT with loss of alert or non alert status and has to be split up. No such issue with .gpx
communicator
Been liked: 6 times
France
JohnnyRidesAlone wrote: 12 Aug 2020 12:22 I found that if you save your Basecamp files as a .gdm file instead of a .gpx the file goes over to the XT with loss of alert or non alert status and has to be split up. No such issue with .gpx
"if you save your Basecamp files as a .gdm"
this type of file does not exist when exporting from BaseCamp !
Exist .gpx, .gdb, .csv, .klm, .tcx et .txt
JohnnyRidesAlone
Been liked: 9 times
Sorry should read .gdb.
