https://www8.garmin.com/support/downloa ... sp?id=4449
Changes made from version 4.8.4 to 4.8.6:
Fixed label rendering with some Unicode maps
Fixed issue where certain European Birdseye downloads would fail
Fixed Garmin Support weblinks
Fixed various crashes and bugs when plugging in certain Garmin devices
Has anyone had an opportunity to give 4.8.6 a try?
BaseCamp Mac 4.8.6 released
Re: BaseCamp Mac 4.8.6 released
Is this the upgrade from 32 bit to 64.
I upgrade to catalona and lost my basecamp ability.
Jon, I believe 4.8.3 and later are 64-bit although I’m not on Catalina yet.
Following a basecamp update some time ago this feature was removed so now you have to export the route from basecamp and then import the route in to Google Earth, then you can view (or fly over) the route.Iris wrote: Sat Nov 09, 2019 4:37 pm Does google earth work with update?
Anyone know?
It isn't as convenient a process, however at least it is still workable.
Hope that helps.. Tony
