Page 1 of 2
Garmin Explorer stuck when uploading large .gpx file
Posted: Thu Apr 10, 2025 9:53 pm
by blahooma
I'm trying to upload a large .gpx file to Garmin Explorer so I can send it to my Garmin Zumo device. I select the file, but it just keeps "loading" and nothing happens — no error message, and the file doesn't show up in my library.
Has anyone experienced this before? Is there a size limit for .gpx files in Explorer, or could it be something else?
Re: Garmin Explorer stuck when uploading large .gpx file
Posted: Fri Apr 11, 2025 1:02 am
by lkraus
That track is large, but with 13249 track points it should still be within the XT limits of 15000 points per track.
I think there is something else wrong in the gpx formatting, as Basecamp will not load the track:
2025-04-10 20_13_12-Garmin BaseCamp.jpg (12.8 KiB) Viewed 2543 times
I even edited the gpx, removing all but a hundred track points, and received the same error message.
Posted: Fri Apr 11, 2025 7:30 am
by blahooma
This file is read by Google My Maps, and the .gpx file was sourced from here: https://www.geoape.com/tracklogs/umber-eesti-5604
Posted: Fri Apr 11, 2025 8:37 am
by FrankB
The problem is in the MetaData. If I remove the <keywords> line, it loads in BC.
Frank
Try the Estonia Corrected.GPX please
Posted: Fri Apr 11, 2025 8:53 am
by blahooma
Thank you! I understand the file is large, but why doesn't Garmin automatically split it into multiple tracks or something like that? How can I still get this file onto the navigation device?
Posted: Fri Apr 11, 2025 9:07 am
by FrankB
blahooma wrote: Fri Apr 11, 2025 8:53 am How can I still get this file onto the navigation device?
Use the corrected GPX from my previous post.
Edit: In fact I dont recommend using Explore. I recommend using TripManager of course. https://www.zumouserforums.co.uk/viewtopic.php?t=3150
Posted: Fri Apr 11, 2025 9:19 am
by blahooma
Does it load all the way for you? It doesn't seem to load fully for me on the Garmin Explorer.
FrankB wrote: Fri Apr 11, 2025 9:07 am
Posted: Fri Apr 11, 2025 9:39 am
by FrankB
I dont use Explore, but in BaseCamp it loads fully.
Posted: Fri Apr 11, 2025 9:50 am
by blahooma
I got the file onto the Zumo device. Thank you!
Posted: Fri Apr 11, 2025 10:38 am
by FrankB
Glad for you.
Just curious. How did you manage?
