Garmin Explorer stuck when uploading large .gpx file
blahooma
Estonia
Post by blahooma »
I'm trying to upload a large .gpx file to Garmin Explorer so I can send it to my Garmin Zumo device. I select the file, but it just keeps "loading" and nothing happens — no error message, and the file doesn't show up in my library.
Has anyone experienced this before? Is there a size limit for .gpx files in Explorer, or could it be something else?
Estonia trip.gpx
(1.58 MiB) Downloaded 248 times
Re: Garmin Explorer stuck when uploading large .gpx file
That track is large, but with 13249 track points it should still be within the XT limits of 15000 points per track.
I think there is something else wrong in the gpx formatting, as Basecamp will not load the track:
2025-04-10 20_13_12-Garmin BaseCamp.jpg (12.8 KiB) Viewed 2532 times
I even edited the gpx, removing all but a hundred track points, and received the same error message.
blahooma
Estonia
Post by blahooma »
This file is read by Google My Maps, and the .gpx file was sourced from here: https://www.geoape.com/tracklogs/umber-eesti-5604
The problem is in the MetaData. If I remove the <keywords> line, it loads in BC.
Frank
Try the Estonia Corrected.GPX please
Estonia Corrected.gpx
(1.69 MiB) Downloaded 176 times
blahooma
Estonia
Post by blahooma »
Thank you! I understand the file is large, but why doesn't Garmin automatically split it into multiple tracks or something like that? How can I still get this file onto the navigation device?
blahooma wrote: Fri Apr 11, 2025 8:53 am How can I still get this file onto the navigation device?
Use the corrected GPX from my previous post.
Edit: In fact I dont recommend using Explore. I recommend using TripManager of course. https://www.zumouserforums.co.uk/viewtopic.php?t=3150
blahooma
Estonia
Post by blahooma »
Does it load all the way for you? It doesn't seem to load fully for me on the Garmin Explorer.
FrankB wrote: Fri Apr 11, 2025 9:07 am
I dont use Explore, but in BaseCamp it loads fully.
blahooma
Estonia
Post by blahooma »
I got the file onto the Zumo device. Thank you!
Glad for you.
Just curious. How did you manage?
