cradle mount charging problem
ChuckXT
Australia
Post by ChuckXT »
My zumo XT, when using the motorcycle mount and battery fully charged, will cycle through "connected / not connected" every few seconds.
Anyone else experience this?
I am guessing when the battery is fully charged is draws very little or no charging current so the device thinks it is not connected. Then, a small current is drawn and the unit thinks it is connected again. Only a guess.
If so, bad charging design!
MotoToph
Has liked: 32 times
Been liked: 16 times
Re: cradle mount charging problem
Post by MotoToph »
This is not normal and have never had this happen with any of my Zumo's. Have you tried cleaning the contacts?
ZUMO XT
K1600GT
ChuckXT
Australia
Post by ChuckXT »
Yes, I've covered all the obvious checks, different charging sources, connectors etc. it is a behaviour of the fully charged zumoXT.
MotoToph
Has liked: 32 times
Post by MotoToph »
Well it should've do that. Mine is always on the powered mount.
ZUMO XT
K1600GT
Garmin has produced an "improved" cable. AFAIK, they replace the old ones at no charge. There is a discussion here that includes a picture that helped me identify whether I had the old or the new one. I had the old which had been trouble free however I called Garmin and they readily sent me the new one.
Also, there are discussions here that contain tips about adding a spacer behind the cable pin assembly in the mount (I used a piece of foam weather stripping). This adds pressure to the back of the pin plate helping insure the pins stay in contact with the XT. There is a picture of the foam trick here somewhere too. I will be back with the URLs to those discussions if I can find them.
All of that said, if your XT is new than none of the above should apply and contacting Garmin is probably the best thing to do.
Edit: This discussion shows both the old and new cable as well as the foam trick.
viewtopic.php?p=16160
ChuckXT
Australia
Post by ChuckXT »
Thanks for the info. Yes, I have the new mount as shown in your photo.
However, the problem lies within the zumoXT charging circuit sensing.
ChuckXT
Australia
Post by ChuckXT »
Thanks Peobody.
After reading your post and looking at 'Rofar's post about reinforcing the back of the mount connector I tried that and - so far so good.
It seems it was the lack of sufficient pressure on the 5V pin contacts on the motorcycle mount.
And, I have the 'new connector' that was suppose to fix the problem---try harder Garmin!
This happened to me this fall. I did two things:
- cleaned the mating surfaces with a pencil eraser, and
- used a dab of dielectric grease on the pins and worked them in & out.
twowheelstom
Has liked: 146 times
Been liked: 54 times
Post by twowheelstom »
rbentnail wrote: Thu Jan 09, 2025 10:59 am - used a dab of dielectric grease on the pins and worked them in & out.
those 2 pins on that rubber charging plate are on springs? what about a squit of WD40 degreaser on the pins to unstick them?
Zumo 396
1994 Yamaha 250
finerone
Post by finerone »
It's interesting how a simple mechanical adjustment can fix what seemed like an electrical issue. Garmin should probably take note of this common problem with their mounting system. Cheers for sharing the fix - might help others with the same Zumo XT charging headache.
