Hi - I have an XT2 and also have the Tread app installed on my Samsung Android phone. I haven't worked out exactly what is happening, but the Tread app is killing the battery on my phone, and sometimes even when I haven't used either the Tread app or switched my XT2 on.
If I notice that my battery on my phone has suddenly lost a lot of charge, I go into Settings > Device Care > Battery. Here I will see the Tread app is at the top of the list of apps that is using the battery. From within Device Care I can select the Optimize option to put background apps to sleep which, usually but not always, fixes the problem. This is fine as long as I spot that my phone is discharging, but if I'm riding my bike I don't see the state of the battery on my phone and end up with a near flat battery - I now have to carry a battery pack in my top box so I can recharge my phone.....grrrrrr!!!
Any ideas as to how I can stop the Tread app from doing this? Any help would be greatly appreciated as this is driving me mad!
Thanks!
Tread app drains battery on Android phone
2015 Triumph Tiger 800 XRx
Zumo XT2 + Sena 50R + Samsung S8
electro_handyman
- Has liked: 2 times
- Been liked: 41 times
Re: Tread app drains battery on Android phone
I had a similar issue with the Drive app when it was 1st released. I couldn't stop it from loading in the background when I didn't need it.
I ended up totally uninstalling it when I didn't need to use it. it was a pain, but it was the only way I found at the time.
I have noticed that since my last install for a trip last month that it is not loading in the background anymore unless I start it. So maybe they found their bug. That or my android system is working better... Time will tell.
- lkraus
- Has liked: 87 times
- Been liked: 248 times
By coincidence, I just uninstalled the Drive app because it was always running in the background. My phone gets little use as a phone, mostly I use it to read ebooks, listen to audiobooks and music, check the weather, do a little forum browsing. I noticed last week that Drive was always the biggest user of my battery power, even though I had not used the app or my XT. I tried turning the phone off and back on and a day later Drive was back as the biggest battery user. It is not a huge drain, but it is still about 6-8% over any time period, which I think is too much for an app that is not doing anything.
I'll reinstall it as needed, and hope that a newer version will come out that can run only when I launch it.
Thanks @lkraus and @electro_handyman for your replies.
For now I've uninstalled the Tread app from my phone as, for example, one morning after a full night of charge, the Tread app had consumed 79% of the phone battery by mid-day. I think it's the unpredictability of the consumption of battery that is so annoying.
I'm also wondering whether it's something to do with my Samsung S8 as if this was a common issue I would (a) have found many results on the internet for this issue, and (b) had more replies from this forum. I've promised myself that I will save my pennies and I'll be replacing my S8 with a S24 before the end of the year.......I will see how that goes with the Tread app. I'll also try re-installing the Tread app at some point just in case it makes a difference, but the version I uninstalled was the current version.
