Garmin Zumo XT Went Dead Again
Jim1348
Has liked: 26 times
Post by Jim1348 »
My Garmin Zumo XT went dead again. It had been on a 6 amp 12 volt power supply for a few hours. I turned it off and it would not power up, again.
The last time that happened, I left it on the power supply over night and in the morning it did power up again. I am trying that again and hope it comes back.
I recall reading here that others have has the same issue.
Been liked: 561 times
Re: Garmin Zumo XT Went Dead Again
I have had mine fail to wake up from standby after stopping during a ride, twice. An overnight on an AC wall charger cured it both times.
twowheelstom
Has liked: 146 times
Been liked: 54 times
Post by twowheelstom »
6 amp charger? you said 6amp at 12 voits. isn't that too high an amps? I would feel better using 1.5amps or no higher than 2.1
Zumo 396
1994 Yamaha 250
Jim1348
Has liked: 26 times
Post by Jim1348 »
twowheelstom wrote: Fri Mar 08, 2024 3:59 pm6 amp charger? you said 6amp at 12 voits. isn't that too high an amps? I would feel better using 1.5amps or no higher than 2.1
No, that is not a concern. My vehicle has a 10 amp 12 volt power outlet and I have plugged in devices, like my Garmin, that don't need that much.
Now, if you have a device that requires 12 VDC and you increase the voltage significantly, you will have a problem at some point.
