CN EU 2025.10 NTU
- Has liked: 114 times
- Been liked: 77 times
Re: CN EU 2025.10 NTU
Have updated my 396 and XT ok but Garmin Express says that the 2024 maps are the up-t0-date ones for my 595, when Garmin says the 595 has NTU maps
https://www.garmin.com/en-GB/p/536397#maps
Maybe this helps someone with the same problem:
When I tried 'Install maps to computer' it failed. Tried a few different things, when I restarted Garmin Express as admin it worked.
With new GE you can ´t install maps on jour PC. Error download.
With old ver. install without problem.
- Has liked: 3 times
- Been liked: 25 times
Just updated my Nav V successfully with EU NTU2025.1 but it has left NTU2024.1 on the sd card (mainly but not only file: D6210260A.img 3gb). This is bound to cause confusion.
Any safe way to delete it?
If you're sure it's the old map you can just delete the file. However it shouldn't cause confusion unless you have both old and new map selected.
